McLeod Adjustable Master Cylinder, 1998-2002 LS1 F-body
Old 02-16-2010, 12:43 PM
sbackof's Avatar
Default McLeod Adjustable Master Cylinder, 1998-2002 LS1 F-body
This is for anyone with a 1st Gen MC. that needs a rebuild kit as they no longer carry this due to a falling out with the company. To tell if you have a 1st Gen look on your boot and if it has the letters CNC you have a 1st gen. So contact 619-275-1663 and the rebuild kit is part number 910ML and its $35 bucks. Hope this helps any who need it.
and this is for McLeod Adjustable Master Cylinder, 1998-2002 LS1 F-body.....I got mine through Thunder Racing
Old 02-20-2010, 09:01 AM
Eskimo's Avatar
Thanks for the heads up.. I am pulling my 1st Gen MC this weekend, and was going to contact McLeod for warranty... Did this fix your problems? if so, how long has it been in there?
Old 02-23-2010, 12:59 PM
sbackof's Avatar
Im ordering it now, so Im hoping it completely fixes the issue. Ill post after its back in. Ill take photos too and try and do a how to for it if anyone is interested.......
Old 02-23-2010, 01:20 PM
sbackof's Avatar
Ok I just talked to Karina at CNC, and she said that they are not designed to run any Synthetic or Silicone brake fluids, only regular El Cheapo DOT 3, Which I was using a Synthetic Dot 3, and you can expect about 2-3 years give or take on a street driven car, but can get up to 10 years possible, Flush system annually and such. So Ill have it tomorrow morning. Make sure you have snap ring pliers. mine has lasted almost 3 years.
Quick Reply: McLeod Adjustable Master Cylinder, 1998-2002 LS1 F-body
