What else should I do when changing clutch to help shifting?
Old 02-18-2010, 08:57 AM
adrynalinjunkie's Avatar
Default What else should I do when changing clutch to help shifting?
I am going to take out the Spec Stage 3 and install a Monster stage 3.
I am doing a full kit from Tick, but I am wondering what else I can do to improve shifting on the street, yes I do allot of WOT shifting and will be running DR's
The car has 37,000 hard driven miles should I change sycros while I have the tranny out or do anything else to improve shifting?
Thanks, Zach
Old 02-18-2010, 10:49 AM
the_merv's Avatar
Drill Mod and Speed Bleeder..
Old 02-18-2010, 11:14 AM
wytry's Avatar
Tick Master Cyl
Old 02-18-2010, 11:20 AM
RsSean's Avatar
Well if your full kit includes a Tick master, then that should do just fine. A speed bleeder will make it a lot easier to bleed to get air out.
Old 02-18-2010, 12:07 PM
Taken4granted's Avatar
Like mentioned above, Tick Adj Master Cylinder, Speed Bleeder, ....and a MGW Shifter. should work wonders for your Monster
Old 02-18-2010, 09:31 PM
MGW should be here in a few days with the brass shift bushing from Tick, I am getting the adj. master from Tick and I will research the drill mod now.
The spec 3 still hooks good but it makes a whine when engaging the clutch first thing in the morning and is damn near locking me out of 2nd, so it is time to let my Left leg go back to normal size
Old 02-18-2010, 10:13 PM
RsSean's Avatar
No need to do the drill mod the master comes with a new line that is more than enough.
Old 02-19-2010, 12:55 PM
Engine_HP's Avatar
as what others have said hydraulics
Old 02-19-2010, 02:29 PM
Black FormulaLs1's Avatar
what about getting a Z06 Slave Cylinder? and if you have the coin..might as well send your tranny to tick and get them to do a stage 2 build if you are lead footed and gorilla fisted...
Old 02-19-2010, 02:37 PM
the_merv's Avatar
What's the difference in the Z06 Slave..
Quick Reply: What else should I do when changing clutch to help shifting?
