what clutch shouldi got with??
Old 02-27-2010, 11:06 PM
vogun16's Avatar
Default what clutch shouldi got with??
i have a 98 camaro ss turbocharged 6 speed, im running 9lbs of boost and putting 500whp and 550wtq, right no i have the stock clutch in and its slipping at high rpms with all the new power. just curious on what would be a good clutch to go with and is also cost efficient.. also sometime when im on it sometimes the clutch pedal will actually stick to the floor! any ideas on why?? thanks!
Old 02-27-2010, 11:10 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Monster clutch and Tick Master cyl.
Old 02-27-2010, 11:14 PM
bigj2717's Avatar
+1 the tick master will fix your pedal issue and the moster clutches are great.
Old 02-27-2010, 11:15 PM
Lambert695's Avatar
Spec 3+ if budget... Monster if not.
Old 02-27-2010, 11:22 PM
vogun16's Avatar
thanks! why is the master cylinder causing the clutch to stick?? it never did this until i put the turbo in
Old 02-27-2010, 11:24 PM
vogun16's Avatar
whats the difference between the the spec stage 3 or the spec stage 3+?
Old 02-28-2010, 06:38 AM
Justins00ss's Avatar
I do believe the 3 plus uses a different material on the disk. Not too sure though. I am running a Monster 3 with a new slave and new stock clutch master with no issues at all. One of the best clutches Ive had in along time.
BTW I noticed your car is tuned by Slowhawk. He is a great dude. I used to live down the street from him. He did all the tuning and cam work on my SS too. I know he is a vendor for Monster so you might want to see what kind of deal he can cut you....
Quick Reply: what clutch shouldi got with??
