slave quick disconnect problems!!!
Old 03-14-2010, 08:15 PM
stdjsw311's Avatar
Default slave quick disconnect problems!!!
ok so i have been trying to disconnect the line to slave cylinder but with no luck. my car never had the little white disconnect tool on it. so i made one out of a coke can but just crumpled up. so i made a double layer "really nice" one and i put it in there as far as it would go but would not come release the teeth on the quick disconnect.....quick my ***.....what can i do???
Old 03-14-2010, 09:33 PM
mayerichm's Avatar
I bought the assortment of fuel line disconnects and one of them fit. I had more of a problem getting it back on.
Old 03-14-2010, 09:39 PM
stdjsw311's Avatar
do u have have a part number because all of the ones i have bought don't fit.
Old 03-16-2010, 03:03 PM
stdjsw311's Avatar
anyone else?
Old 03-16-2010, 03:31 PM
ABQ99TA's Avatar
I just pulled mine off with two flat haed screwdrivers yesterday. It is not that hard, just get two flatheads and press the white ring in as far as you can it may take a few times but I've done it like 3 time that way.
Old 03-16-2010, 03:41 PM
stdjsw311's Avatar
the problem is i dont have a white ring....everyone else had one on their car but me. lol kinda sucks. i dont know if someone broke it off before i got the car or what happened
Old 03-16-2010, 03:43 PM
blubyu02's Avatar
i just used the white one and 2 flatheads it came off pretty easy with no problem. on the way back in it snapped in and that was it
Old 03-16-2010, 03:53 PM
ABQ99TA's Avatar
If you can't see the white ring I think you are in trouble. I'm not sure how you could get it out if you can't press the white ring in. Could it just be dirty? Did you clean it off and get a good look at it? Maybe someone will know a trick. But if the ring is some how broken in a way that it is still holding the line in and you can't see it I have no idea how to take it out. Maybe you could disconnect it from the master and pull the line out with the tranny.
Old 03-16-2010, 03:58 PM
stdjsw311's Avatar
i have replaced the slave before and i used teh coke can trick to get it off last time but no luck this time. i will try to take a pic tonight to show you whats going on with it.
Old 03-18-2010, 10:03 AM
stdjsw311's Avatar
sorry still have not got the pic
Old 03-18-2010, 10:08 AM
the_merv's Avatar
That's when you take it off their car and let them worry about it..
Old 03-18-2010, 12:43 PM
mondi2002's Avatar
Make sure you push the whole line connection in when pushing
the ring or what have you.
I usually have to push everything in then wiggle it and pull out.
Quick Reply: slave quick disconnect problems!!!
