Problems with T56
Problems with T56
I have a 02 TA with a T56 and I am having problems getting it into 1st gear. If I put the car in 2nd and roll a couple of inches forward it will go in fine. It also grinds when I try to shift from 1-2 unless I shift real slow then it won't grind. I replaced the master cylinder a few days ago and I replaced the clutch and slave cylinder about 15,000 miles ago. The clutch is a spec stage 3 and it worked fined for about 13,000 miles after the clutch swap. What could this be?
