3-4 only? how come?
Old 03-21-2010, 06:08 PM
Daez's Avatar
Default 3-4 only? how come?
Just curious, but why is it only the 3-4 forks that seem to break?
Old 03-21-2010, 07:05 PM
jmd
jmd's Avatar
I've worked a broken 5-6 fork trans. if it makes you feel better.
Old 03-21-2010, 08:40 PM
thesource's Avatar
I've had units with busted 1-2, 3-4, 5-6 and reverse forks in the past. Usually the 5-6 and reverse forks go bad from driving with worn out or busted fork pads and it eats into the metal of the fork. I've seen busted 1-2 aluminum forks just like you see with the 3-4 forks. Its just that the 3-4 fork failing is much more common but thats true with a lot of 5 and 6 speed performance type transmissions.
