clutch job buttoned up now wont start
Old 03-21-2010, 06:37 PM
bigti99a's Avatar
Exclamation clutch job buttoned up now wont start
hey guys what do i need to check. i have looked over everything and it all looks good. but the car wont even try to start.
Old 03-21-2010, 06:58 PM
Joshiedoom's Avatar
Did you rip off the exciter wire off the starter? Check fuses and wiring etc.
Old 03-21-2010, 09:09 PM
ArcticMissile's Avatar
If its not even turning over then the problem is most likely electrical. Does the radio and rest of the electrical in the car work? If so I would check the starter wires and any plugs into the transmission. Also of course check the fuses. Good luck!
Old 03-21-2010, 09:27 PM
nmass399's Avatar
Yeah i am guessing blown fuses for the starter, or starter wires ripped off, probably not the problem but is the clutch pedal touching the sensor so it will let it start, not sure if you changed out the master cylinder or not or did anything else under there. And i would definately check all other fuses to just in case.
Old 03-22-2010, 07:07 AM
bigti99a's Avatar
yeah i checked all sensors for the clutch and everything is hitting fine. just to make sure we tryed to jump the clutch switch, still nothing. also i put a tester light and all fuses are fine. i get power to the posts of the starter. i also get power to the fire post when the key is turned all the way forward.
we have tripple checked all electrical connections and sensors. could my starter have gone bad just hanging there out of the way? i never had a starting issue with my car...until now.
Old 03-22-2010, 11:33 AM
the_merv's Avatar
Yea it could've gone bad just hanging..could have got a hair-line crack internally on one of the posts.
Try smackin it with a Hammer and see what it does.
Old 03-22-2010, 12:09 PM
bigti99a's Avatar
yeah we beat on it and nothing. also tried to jump it, no dice. at work now. hope to start wrentching in a few hours. i got a starter today. if that doesnt work i am going to be super stumped.
Old 03-22-2010, 01:12 PM
the_merv's Avatar
Yea try a different Starter.
If you are gettin 12V at the end of the purple 12ga Wire then it's definately the Starter. If it's bolted to the block then no way you have a bad ground.
Old 03-22-2010, 03:12 PM
bigti99a's Avatar
SHE'S ALIVE!!! AND THE CLUTCH PEDAL FEELS LIKE BUDDA! new starter did the trick. now time to break the clutch in and see what i have in a few weeks!
Old 03-22-2010, 04:18 PM
nmass399's Avatar
Glad you got it runnin man, its sucks when having to search for a problem like that.
Old 03-22-2010, 04:26 PM
Congrats!!
Old 03-22-2010, 05:06 PM
bigti99a's Avatar
thanks guys. everyone here is always real helpful. everything always go's smooth until your workin gon your own car. then hell breaks out. headding out of work to go rack up some miles.
Old 03-22-2010, 11:22 PM
slowpoke96z28's Avatar
i guess from now on i'll remove the starter like i'm suppossed to instead of letting it hang for any starter that size or bigger.
Quick Reply: clutch job buttoned up now wont start
