t56 hard to get in gear
Old 04-08-2010, 11:37 AM
gooseit1983's Avatar
Default t56 hard to get in gear
i just replaced my clutch in my ta an now i am haveing a hard time getting it into gear while running. i can not figure out why please help
Old 04-08-2010, 01:31 PM
99ssleeper's Avatar
what clutch? did you replace any other parts? miles on the car? any problems with the install?
more info needed.
Old 04-08-2010, 01:32 PM
bongva's Avatar
shims? maybe a bad slave/master?
Old 04-08-2010, 02:03 PM
my1994z28's Avatar
Make sure the clutch fork is fully engaged on the throwout bearing
Old 04-08-2010, 03:47 PM
fotoboy's Avatar
you have a adj master? If not you need one w extra throw. Tick is the best from what i have heard
Old 04-08-2010, 04:23 PM
99ssleeper's Avatar
good advice considering there is no clutch fork.
post more info about your setup. theres no point in throwing out ideas without knowing the basic info.
Old 04-09-2010, 09:02 AM
i repaced it with a speck stage two and new gm flywheel. i also put in a new slave unit in the trans i have bleed it 3 diferent timesi can not figure it out
Old 04-09-2010, 09:05 AM
the car has 115000 on it but, it was towed for half of those miles. other than that it is stock. i have had it for going on tree years and have had no problems, it is driviung me nuts
Old 04-09-2010, 09:57 AM
99ssleeper's Avatar
did you put the shim behind the slave cyl?
Old 04-09-2010, 10:16 AM
yes i did, fallowed the directions to the t
Old 04-09-2010, 11:22 AM
99ssleeper's Avatar
what shifter do you have? is something pinched in the shifter area? shifter boot problem? doesnt sound like a hyd issue although that master may be getting weak.
Old 04-09-2010, 11:39 AM
it is the factory shifter and has no boot issues some times it feels like i can pump the clutch and it goes in gear easier. and when i go to let the clutch out it almost instantle is engaged
Old 04-09-2010, 11:42 AM
it goes in gear just fine when the car is not running
Quick Reply: t56 hard to get in gear
