Whats the best LT1 T56 I can buy?
Old 04-14-2010, 11:04 PM
Greg555's Avatar
Default Whats the best LT1 T56 I can buy?
Hi all
Im building a little project car and I need a short shaft T56. There are few on eBay but all very expensive.
I have access to wrecked insurance cars so I was thinking of buying ***** wrecked car but I am not sure what cars did they come in.
Also I've read that some of the T56s are made in Germany and are better than ones made in Mexico. How do I make sure I get the better one.
Thanks
Greg
Old 04-14-2010, 11:18 PM
Sharpe's Avatar
http://www.tick-performance.com/tickshift/
Old 04-14-2010, 11:30 PM
Greg555's Avatar
Originally Posted by Sharpe
Thanks
I still need to get 1 first so what cars do these short input shaft ones come in and what years?
Thanks
Greg
Old 04-15-2010, 06:35 AM
85MikeTPI's Avatar
Originally Posted by Greg555
Thanks
Thanks
Greg
LT1 F-body vehicles.. 1993 -> 1997 (The 93's have wider ratio gears in the T56, the rest are all close ratio)
Old 04-15-2010, 07:18 AM
Invictus_Z's Avatar
That is actually only partially true, there were two M6 trans avaliable for 93' (M28 and M29) M28 is the wide ratio, while M29 is the close ratio and its actually closer than the 94-97 cars. I would say an M29 style gearing would be your best bet, It works great in my car.
Old 04-15-2010, 07:59 AM
85MikeTPI's Avatar
Relative to the MM6, both the M28 and M29 are wide ratio gear sets..
Old 04-15-2010, 08:45 AM
thesource's Avatar
94-97 units are the most common and are all the same. If you buy a used one, you are taking a chance. Buying a rebuilt one with upgrades will cost you more up front but will probably be cheaper in the long run.
Old 04-15-2010, 02:58 PM
Invictus_Z's Avatar
I stand corrected, I went back and referred to my chart and the M29 ratios are wider than the 94-up ratios. For some reason I was thinking otherwise.
GR - M28 -- M29 -- 94+
1 -- 3.36 -- 2.97 -- 2.66
2 -- 2.07 -- 2.07 -- 1.78
3 -- 1.35 -- 1.43 -- 1.30
4 -- 1.00 -- 1.00 -- 1.00
5 -- 0.80 -- 0.80 -- 0.74
6 -- 0.62 -- 0.62 -- 0.50
Old 04-15-2010, 03:10 PM
WSsick's Avatar
great advice.
Old 04-15-2010, 05:44 PM
jmd
jmd's Avatar
I'd want a 1993 M29 unit with .56 sixth, SSR tailhousing, counter and output shaft per Mike's recent research.
In all seriousness, I'd look at gear ratios and what the powertrain was making to see if I wanted to stick with MM6 or what.
Old 04-15-2010, 06:03 PM
85MikeTPI's Avatar
That's a Z51 donor trans SSR hybrid, but abet still an LSx setup... ;-)
Quick Reply: Whats the best LT1 T56 I can buy?
