LS9 clutch on a LS1?
Old 04-26-2010, 09:21 PM
MUSTANGBRKR02's Avatar
Default LS9 clutch on a LS1?
Has anyone done this yet? I have heard that Katech makes a conversion flywheel but just wondering if anyone has done it?
Old 04-26-2010, 09:33 PM
fast377's Avatar
Supposedly you have to run Katech's flywheel AND the ZR1 specific slave cylinder. But, since you can use an fbody slave in a C5, and the ZR1 slave works in a C5, I bet if you could find a flywheel it would all work in an fbody. I thought about trying it a while back, but I never did. It would really be great if you could find a cheap stock flywheel that would work. That would make for a dirt cheap twin disc setup.
Old 04-26-2010, 09:44 PM
1979rs/z28's Avatar
I'll be making some calls tomorrow about it, looks like the most expensive piece will be the flywheel although.
Old 04-27-2010, 05:40 PM
Tudds's Avatar
They don't make a flywheel yet
Old 12-23-2010, 03:28 PM
LS1TECH Sponsor
Katech_Jason's Avatar
First one is up and running
https://ls1tech.com/forums/manual-tr...ch-f-body.html
Quick Reply: LS9 clutch on a LS1?
