hard to get into gear
have a ram 88931 hdx installed that had flywheel resurfaced and had shim out tech told me to take it out so i did and still having problems disengaging also i got a ram 510 adjustable master which didn't do **** had me buying many things also bleeded it so many times and still nothing what could this be i never had a problem with the spec i had. you think i can put the spec 1 pressure plate on the ram clutch disc
thanks
louis
thanks
louis
So you bolted the spec Pressure plate to the ram kit and everything works fine?
Im having the same issue, cant get into gear at higher RPMS, but my issue is with a spec3+ kit.
I changed all of my hydrolics , tried the drill mod, nothing worked. I just pulled the trans yesterday and ill be shippin the spec kit back soon.
I think I have a bad pressure plate aswell.
