Mighty Vac
Mighty Vac
After replacing slave and having air in master.. can you use the Mighty Vac techneque as seen here (http://www.performanceworks1.com/ls1...h_bleeding.htm ) to bleed the whole system, or do you have to vac it then do the bump and bleed method to clear out the new slave to complete full system bleeding??
Thanks to all who respond?
I've never had luck doing it that way, some have I guess.
I found a system that works for me. I bench bleed the master.
After that I barely need to do any bleeding once everything is installed.
