mcleod street twin: loose sounding engagement?
Hello everyone.
I have recently installed a McLeod street twin clutch, and I absolutely LOVE the thing.
438rwhp, Dana 60 rear, and a viper mainshaft T56. This was the final piece. It now has 2000 miles on it, and I have a concern about the engagement..
When I let the clutch out, sometimes it makes a sound like when you would drop a marble into a tin can and it bounces up and down a couple times. I know that is an awkward comparison, but that is kind of what it sounds like.
I have noticed it more when taking off and letting the clutch out not slow, but not dumping it either. It’s definitely a first gear thing too, as it is only when taking off.
Anyone else experience this? I haven’t noticed any performance issues with it.. yet. So if this is a precursor to something wrong, I would rather know now before something bad happens.
Thanks, and feel free to ask more questions to clarify what this sound is...
Cody
Cody
I suppose background info is needed:
I installed the Mcleod adjustable master, along with a brand new GM hose and Slave at that same time. I bled it for an hour off the car with the mighty vac, bench bleeding, and letting gravity do its thing too. The shifting is firm and the pedal travel seems fine. Just wanted to clear that up.
I did have to take it to get balanced a second time, because the first shop did a poor job. Those are the only modifications to this. I have put the washers back in the exact spot that the clutch showed up with.
I've had precisely the same problem with my macleod twin disc. definitely interested to see if this generates any answers. other than the noise in first like you described i've had no issues with it
I read in another post where someone was talking about an identical issue with another brand of twin disc clutch. A response was posted that along the lines of it being driven too slow during take offs and cruising therefore a glaze was building up on the discs.. take it out and let it take off the line and break it in.. I don't know if this entirely true but I think i'll try it in the name of taking care of my car
what do you suggest for the breaking it in that you speak of?
The best advice I have is to put it on a lift and put a stethoscope on it. Try to simulate the sound the best you can. Look at the fork area especially the T stud.
I would say probably not wearing out, but the LT-1 "T-Studs" are notorious for rubbing on the pressure plate cover which can lead to a metal to metal sound.
Cheers
I am going to ask a series of questions so bare with me:
When the car is dead stopped and the clutch pedal is completely pressed down, does the clutch make the noise?
