One of these slaves is not like the other...
So I'm in the middle of my clutch swap and when I pull the old slave I notice it's a little different than the new one...what gives? They're both GM pieces - is something different b/w an LS6 and LS1 slave? I bought the new one from Scoggin Dickey just not sure why it's different.
Looks like the old one is missing the top part, I have mine taken apart right now and it looks like the new piece you have. I think I'm going to pull the trigger on the mcleod. Mine is an 02 z06 also.
That sucks man - it's a little ridiculous to wait over a month for a part. Speaking of ridiculous since I had McLeod balance the clutch/flywheel together they obviously bolted the pressure plate to the flywheel. Well now I can't get the bottom adapter ring off of the flywheel since it's bolted down too tight (when I try to loosen it the whole flywheel just turns on my bench). I'm going to get a flywheel holding tool tonight but in the meantime I'm bolting the flywheel to the crank to keep it from moving and then trying to remove the PP/lower ring bolts. I would just leave it bolted on but I want to clean all the parts prior to bolting everything together.
So I'm assuming it's ok to use the slave I posted up?
edit - just called Scoggin Dickey and they say they shipped me Part #89059282 which is the LS6 piece. They were saying it has been redesigned over the years so I guess that's why it looks different.
I just got one with a monster clutch kit for a 98 fbod, and the body of it looks the same, although the bleeder and the master line look to be different, so I would say Your good to go, at least I hope so since were both in the same boat.
