Clutch not fully realeasing, help
Old 05-08-2010, 08:06 PM
SSmike1's Avatar
Default Clutch not fully realeasing, help
2000 all stock SScamaro, LS1, 35,000 original miles.
my clutch will not release all the way.
the pedal feels like the clutch is working all the way to the floor,
But i can not get into first gear with the engine running.
engine off, tranny shifts fine,
engine on, can not shift gears.
I bled the hydraulics, no change.
i put a Mcleod MC in year 2004, to prevent hydraulic issues,
and drilled the line.
i think the Master Cylinder is gone bad?
HELP.
what MC should i replace it with?
thank you
mike
Old 05-08-2010, 08:27 PM
X-ray's Avatar
http://www.tick-performance.com/tick...aulics/#master
I've heard nothing but good things about Tick adjustable MCs, and they're a sponsor here. Pricey, but I'll be ordering one sometime soon.
Old 05-09-2010, 08:06 PM
1904gto's Avatar
i have a tick great product
Old 05-10-2010, 12:22 PM
SSmike1's Avatar
thank you! great idea, the tick MC.
how can i rebuild the MCLEOD unit?
Old 05-10-2010, 06:26 PM
offroadfury6's Avatar
HELP.
thank you
mike
I tried to drive my car today...SAME ISSUES! exactly the same problems...lemme know if it the master cylinder or not...guess I'll be buying one next week.
Old 05-10-2010, 09:03 PM
SSmike1's Avatar
YES, it is the Master Cylinder.
the rubber puck, is letting air inside, not allowing Full Throw on the slave cylinder.
i ordered a Rebuild kit for the Mcleod M/C.
if that does not do it,
i'll need a new MC.
Old 05-10-2010, 09:04 PM
SSmike1's Avatar
i called mcleod, and they sent me to a CNC machining company,
who does their rebuild kits now.
CNC = 1-619-275-1663 = phone #
and they wanted $35 for the rebuild kit 910ML
for the 2004 Era MCLEOD Master Cylinder i have...
mcleod does not sell or give them away anymore.
THANK YOU VERY MUCH FOR THE HELP!!!!!!!
Old 05-10-2010, 09:57 PM
actually ill be buying tick performances master cyl. packages. includes
-monster clutch
-tick master cyl
-new slave cyl
-throwout bearing
-pilot bearing
-clutch adjuster tool
-flywheel
costs $1129.99 !!!
dropping the tranny out Wednesday, keeping it out until tick performance is free for a re-build
Quick Reply: Clutch not fully realeasing, help
