Please look at this picture of my hydraulic slave line! I need help!
Old 05-19-2010, 08:35 AM
SpecV44's Avatar
Default Please look at this picture of my hydraulic slave line! I need help!
Went out tuning, @ 110 in 4th gear (first WOT run, checking AFR), pushed in the clutch to slow down. When I did, it stayed at the floor, pulled it up with my toe, then it was rock hard. Tapped on the pedal, then pushed it to the floor, when I did that, I knew something happened. Pulled over, puddle under the car, but since it is lowered, I could not see under it. I came home, jacked it up and the hydraulic line just pulled right out of the slave, and I look at the end of it. Below is a picture of the end of the line, and a picture of what it should look like. Please tell me what happened so I can ensure I change the correct parts.
This is mine:
This is what it is supposed to look like:
Old 05-19-2010, 11:47 AM
7camaro7's Avatar
braided line may have not been connected correctly in the first place. It should snap in. remember my mc with drill modded line is still for sale.
Old 05-19-2010, 01:02 PM
SpecV44's Avatar
Yep, havent forgotten about ya lol. I just wanted to get a little input before I decide who to get it from. If there is a chance my master could have been damaged, I want to ensure I pick up a master at the same time.
Old 05-19-2010, 02:45 PM
Taken4granted's Avatar
7camaro7 is right, it may not have been connected right it should snap in, and be a bitch to take out. but from looking at it I can tell your fluid needs to be changed because its been contaminated by clutch dust , so I recommend bleeding your clutch system. if the problem persist you may have to 1. get a new master cylinder or 2. change your hydraulic slave. I had that problem where it got stuck to the floor and wouldnt go into gear.
Old 05-19-2010, 07:36 PM
SpecV44's Avatar
the clutch fluid was BLACK, so we completely flushed it out and put new in, it must be stained.
it seems at this point I will at least change the line and see where it goes from there.
Old 05-20-2010, 10:52 AM
TAtoad's Avatar
x2 on it being a bitch to take out (for me it was).
Old 05-20-2010, 11:40 AM
SpecV44's Avatar
yeah, i know it should have been a PITA, as we have removed the transmission 5 times. This is the first problem I have had with it, but it was also a new slave that doesnt have the same retention "fingers" as the GM slave. The one that I put in from Advance Auto Parts has more of a clip than the "fingers". I am going to change the line, put in another new slave, and use the GM slave hookup (female line side). I bet it solves the problem.
