T56 goes in between 3rd and 5th gear?
On the way home from work I gave the car a few good rippings and I found every now and then when I go for 3rd it will actually go in between 3rd and 5th. Brand new Pro 5.0 shifter properly adjusted. Clutch gets good air gap (.040"). No other shifts will this happen on, just when going for 3rd. Trans was purchased used online years ago, said rebuilt but then and especially now I do not think so. It will rev like it is neutral when this happens.
pretty sure you messed up a syncro, sounds like what happened to me a few years ago, you need to rebuild it as did I. Eventually it might stick in between the gears as that's what ended up happening to me on the freeway at 85 when i was playing in my car, I had to pull my foot of the gas pedal and press it against the center of the dash board and yank as hard as I could on the shifter to get it back to neutral
Never had the original shifter. Trans was swapped in 3 years ago with the Pro 5.0.
Ok guys a little update. I have not driven the car much in the last few weeks but had it out this weekend. This little problem has become worse. It is more common to shift into this "hidden" gate than not to under any kind of heavy throttle (say WOT and over 3k rpm) and only when going for 3rd. If it s goes into this area I can usually push the clutch in, pull it out and stab it into 3rd but by then the RPM's have dropped substantially. Normal driving it shifts perfectly, no grinds... noise... nothing. 4th is no problem at any rpm so does that rule out a bent shift fork? Am I looking at a bad syncro?
I remember it looking OK last time I had the shifter off, but not great. I am going to remove the shifter to increase the spring pressure and see if that helps so I may just order a new cup and see if it helps.
Nice, thanks for the help. I do think I will be ordering one just for sanity sake. How is it held in place when I remove the stocker?
Would love to find out this is just some weak shifter springs and a beat shifter cup. I drove it to work today and the trans works flawless. Not a hint of grind or anything. Didn't go WOT as I was trying to save some fuel but I got on it a couple times with some RPM and she is spot on. And I would rather get these parts in before I try anymore hard shifts. Afraid if it isn't something internal it may become from beating on it with this issue.
It doesn't get stuck out of 3rd like something is blocking in, it just finds some hidden gate. I have yet to find anyone else have this in A LOT of searching over the last few weeks.
I will say the shifter does not return to center like it did when new, seems kinda lazy. And it has only been used for less than 2k miles.
Ok guys I think Phynix hit it with the first reply.... syncro.
I drove it to work a few times last week with zero issues. But it is a 50 mile ride one way and I usually would not bother getting on it till I was near work or near home so the trans was fully up to temp. It sat most of yesterday and I took it to the store (not even 10 miles). Just down the road from home she grinded nicely going into 3rd on a very tame shift as I was just taking off from a red light. After thinking about it any problems I have had with 3rd gear are when the trans is not fully hot like after a long drive. Once hot it works perfect.
Can a syncro stick when cold? What causes one to stick if so?
Just trying to get an idea of what I will have to look for when I rebuild it this coming winter in hopes it stays together for this summer so I can at least drive it.
Time to start ordering parts... bearing kit, snap ring and shim kit, new 3 syncro, etc etc.
I was having very similar problems. I found that my third gear syncro was wore and I had a busted key in the 3/4 slider assembly. I am in the process of rebuilding mine with a Tick level 2 kit.
Changing the shifter to a known-good one, and getting a new offset lever plastic (less vibration) bushing with correct adhesive should come before anything internal. The F-body shifter includes springs which center it. Which shifter you have may change what you want to do with it; some can have new springs installed easily.
