Where to get hard parts?
Converting from a vette to F Body setup, and I need the part that goes on the shift rail under the middle shifter plate guided by the guide plate. Also, do I need the skipshift lever if Im not running the skipshift? Where can I get these parts?
I've been able to grind off the Rev-lockout arm from the early C5 units and use them in conversions. I also grind off the CAGS arm at the same time.
