Help Bad knocking noise during Idle
Old 05-30-2010, 10:39 AM
corvet786c's Avatar
Default Help Bad knocking noise during Idle
I just installed a centerforce 12 inch version clutch and everything was fine until this morning. Car shift fine even thought the pedal feel is very light for some reason. Clutch resevor is full.But it shifts. All of a sudden while I am driving I hear this light now ticking and gettin louder as rpms go higher. It sounds inside the clutch assembly area. I dont know what it could be. I know with the 11inch version the pedal feel was much harder to push down. I am concerned. Any Ideas?? The slave has been changed about 10,000 miles ago. And this is a new clutch I bought. I am trying to break it in properly so I have not gave it full throttle yet.
Old 05-31-2010, 11:59 AM
corvet786c's Avatar
so no one can answer this?????
Old 05-31-2010, 04:15 PM
thesource's Avatar
Just a guess...... but sounds like something is hitting inside the bellhousing due to install the larger clutch kit with a larger pressure plate. I am not very familiar with the Centerforce 12" pressure plate or the differences other than size over the 11" version.
Quick Reply: Help Bad knocking noise during Idle
