Leaking Clutch Master
Old 06-05-2010, 09:56 PM
z2h8t's Avatar
Default Leaking Clutch Master
So i recently replaced my slave cylinder and couldn't get the braided line out from the actual slave. I pulled the pin that holds the braided line to the clutch master cylinder. After replacing the slave cylinder i reattached the braided line to the clutch master cylinder and tried to re bleed. It came to my attention that the fluid was leaking out from the point where the pin holds the braided line to the clutch master. How do i fix this problem?
Old 06-05-2010, 10:30 PM
Kleeborp the Moderator™
MeentSS02's Avatar
The only thing sealing that connection is a small o-ring...that would be the first thing I would check.
Old 06-05-2010, 10:41 PM
z2h8t's Avatar
yeah i don't have any o ring i guess. where can i get it from
Old 06-05-2010, 11:02 PM
MeentSS02's Avatar
I would hope you could get one from an auto parts store, but I've never tried to source the o-ring by itself.
Old 06-06-2010, 10:09 AM
z2h8t's Avatar
i'll go look around today
Old 06-06-2010, 10:39 AM
MeentSS02's Avatar
Did you keep your old slave cylinder? The input line uses the same o-ring/roll pin type connection as the master cylinder.
Old 06-06-2010, 10:00 PM
z2h8t's Avatar
Thanks alot man! Went to autozone and bought a universal o ring set and found the perfect match. Car runs great!
Old 06-06-2010, 10:03 PM
MeentSS02's Avatar
Awesome...glad to hear they actually carry that particular o-ring. I figured it couldn't be too terribly uncommon...
Quick Reply: Leaking Clutch Master
