M6 tranny problem or clutch related?
Old 06-06-2010, 01:24 AM
tnmotown's Avatar
Default M6 tranny problem or clutch related?
Ok how can I put this.....Pretty much I was getting on it and went to shift into fourth and made is big grinding noise so I threw it back into neutral. Went to put it back into gear and grinded and slipped after only 2k rpms and higher. I had to limp it home as I was not able to go past 30mph because the clutch wasnt holding, while still making a grinding noise and some vibration.
By the time I got home it was done, if I put it in any gear and release the clutch it just made some weird grinding noise and car wouldnt move.
So....today I dropped the tranny and clutch. Its a clutch clutch but everything seemed to be intact still? No busted springs, pp fingers still there, just really dusty and hot spots all over. So I was like "damn, is it the tranny?" Is there a way to test the tranny to see if its that? I just it in gear (4th) and both front/rear shafts turn the same time. I put it in neutral and just front input shaft spins. Sorry If i sound confusing and the long story, just dont want to put in a new clutch and it being the tranny. Any input I would greatly appreciate!!! thanks man
Old 06-07-2010, 01:06 AM
tnmotown's Avatar
Well I believe I found the problem. Is the throwout bearing attached to the slave cylinder? Because I barely touched it and the spring and bearing piece came apart from the slave cylinder. Hopefully that's the problem
Old 10-18-2011, 01:47 PM
t5munoz's Avatar
Did you ever figure out what was wrong with your car???
Old 10-18-2011, 02:04 PM
tnmotown's Avatar
Yep, throw-out bearing busted. Replaced it and drove like new again.
Old 10-18-2011, 02:10 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Good for you, hopefully the grinding you experienced was very limited in any actual hard part damage.
Quick Reply: M6 tranny problem or clutch related?
