Where to get an Input Shaft for the T56 in my 98 Trans Am?
Old 06-25-2010, 07:26 AM
tecmec's Avatar
Default Where to get an Input Shaft for the T56 in my 98 Trans Am?
Where's the best place to get an input shaft for a T56 in a 98 f-body?
And on that topic...I know a lot of guys insist on replacing the pilot bearing with a bushing because the bushings tend to be more durable, but are there any other factors? The bearings must have an advantage over the bushings in some way, no?
Old 06-25-2010, 07:42 AM
85MikeTPI's Avatar
Any transmission/tremec sponsor can get you the input shaft.
Bearings can reduce friction in stock applications, but can suffer under the abuse of racing,etc. YMMV
Old 06-25-2010, 08:16 AM
raven154's Avatar
FYI it's not the throwout bearing you replace with a bushing, it's the pilot bearing/bushing.
Old 06-25-2010, 08:18 AM
tecmec's Avatar
Right, that's what I meant. I'll fix that in my post...
Old 06-25-2010, 08:36 AM
Big_Bird_WS6's Avatar
i say call D&D. they are a great place to deal with.
Old 06-25-2010, 10:04 AM
All-In's Avatar
Location: Just because the voices aren't real, doesn't mean they're not right!
Also might try Jason at TDP. He might be able to help you too.
Old 06-25-2010, 04:02 PM
haighter's Avatar
I would look at thegearbox.org the have had the BEST prices I have seen.
Old 06-26-2010, 10:14 PM
XLR8N's Avatar
Don't go to liberty.......they have had mine for over 4 months and all thy needed to do was harden and respline it.
Quick Reply: Where to get an Input Shaft for the T56 in my 98 Trans Am?
