Chevelle LS3/T56 Help Needed
Old 06-28-2010, 02:35 PM
70LS3Chevelle's Avatar
Thumbs up Chevelle LS3/T56 Help Needed
I'm looking to buy a clutch/flywheels setup for a T56 out of a GTO and L92/LS3 setup. The current flywheels is for a auto so that has to go.
With the tune and cam package I should be around 550HP at the flywheel.
Drivability is important for me as well.
1)What size clutch do I need a 11" or a 12" setup?
2)What kind of flywheel should I go with?
I can get this Centerforce dual friction at a great deal would you recommend this or is this even the right clutch?
A budy suggested an LS7 cluch?
http://www.summitracing.com/parts/CT...ke%7cCHEVROLET
Flywheel:
http://www.summitracing.com/parts/MCL-460530/
Thanks for the help!
Old 06-28-2010, 04:42 PM
85MikeTPI's Avatar
I plan on the LS7 kit for my L92/T56 swap later this year..
http://sdparts.com/details/scoggin-d...center/sdls7ck
Old 06-28-2010, 11:22 PM
Prices seems good. I'm considering the Ram Aluminum Flywheel to go with the LS7 Clutch.
Old 06-29-2010, 07:21 AM
85MikeTPI's Avatar
I'm not a fan of Alum FWs for street and heavy cars. If your Chevelle is over 3400# and street/strip, I'd stick with the steel FW..
Just my $0.02
Quick Reply: Chevelle LS3/T56 Help Needed
