Does these clutch can be adjust ? my revert is grind some time, i guest my clutch is not fully adjust yet. every other gear shift fine and no grind or noise.
Is the clutch fluid new and not dirty?
Also has it been bled recently? If there is even a little air in the system it can cause disengagement issues.
Hope this helps.
--Glenn
Hope this helps.
--Glenn
how can I tell the fluid is dirty ? preview owner just pay 1000 on replace with gm clutch , it just turn 510 miles, you think the mechanic dint bleed clutch properly ? clutch seem really stiffy.
