AC Delco Master Cyl any good?
Old 07-09-2010, 09:57 AM
ChvyCruzen's Avatar
Default AC Delco Master Cyl any good?
My clutch went to the floor while I was at work ... a month ago. I'm tired of having my car in the garage and not able to drive it. I tried pumping it about 30 times, using my hand and it didn't build up any pressure. I assume the Master went, I checked the fluid level after pumping it and there was no change, so I should not have a leak in the line or slave.
I dont want to spend a lot of $$ on a Tick ... YET. My 01 SS has 40k miles and all stock, I want to keep it that way for several years until I decide to make a race car out of it...
Is the ACDelco 385514: CLUTCH MASTER CYLINDER any good? Will it be like stock?
Old 07-09-2010, 10:51 AM
Internet Mechanic
BlackScreaminMachine's Avatar
The Tick unit is a HUGE upgrade from stock, its not going to degrade the value or driveability at all. IF you not looking to spend money, then at least get a RAM adj Master. It is a GM M/C with a adj. Rod end.
Quick Reply: AC Delco Master Cyl any good?
