Grinding at high rpms and sometimes when shifting
Old 07-10-2010, 02:23 PM
Zerokube's Avatar
Default Grinding at high rpms and sometimes when shifting
Seems my car likes to grind gears when im shifting at high rpms and occasionally when im just shifting like normal. Anything?
Old 07-10-2010, 02:28 PM
killagt's Avatar
When last time you change your tranny fluid ? and bleed clutch ? what gear is grind the most ? either need new clutch or bad tranny syncro.
Old 07-10-2010, 03:18 PM
2TheFloor's Avatar
Sounds like one or more synchro's are worn. Might be time for a rebuild.
Old 07-11-2010, 10:17 AM
Zerokube's Avatar
Haven't touched the tranny fluid yet, plan on it though. It grinds randomly when just regular driving but when i hit high rpms it grinds always. clutch fluid is a little dark and haven't bleed it yet.
Quick Reply: Grinding at high rpms and sometimes when shifting
