6 speed for Gen 1 sbc
I want to get the man pedal in my vette. Its my autox/DD at the moment so would like to get used to driving it with a stick before hitting a roadcourse. And the better MPG is a plus.
Ive heard the LT1 T56 is the way to go as its a push(or pull) setup. The one I need in other words.
Is this a fairly easy swap?
I know Ill need the trans, slave, clutch, flywheel, and DS. Am I missing anything?
Is there a better trans to go with?
Easy question, hard to answer. How many bricks are in a pile? How long is a piece of string?
Not knowing your skill level and shop equipment makes your question impossible to accurately answer...but if you can't look at what's involved and answer it for yourself then it will probably be a difficult project.
Yes, the XTrac sequential trans is a better gearbox.
Haha still want a daily driver without a 8000+ trans
Cutting the hole in the floorpan/tunnel for the shifter was the only difficult part I encountered, all else was bolting and wiring.
