HELP! Installed Tick MC, where is bleeder??
I've been searching for the past hour to find the bleeder screw on the tranny/bell housing and CANNOT FIND IT. I followed the sticking clutch pedal write up but the picture showing where the hole in the car does not show up. I want to drill my car but cannot find the right location to drill. PLEASE HELP. Thanks in advance guys.
there is a hole right above where the master line plugs in. in that hole is the bleeder and only way to get to it is a 10mm socket i think. you can drill you trans tunnet and get to it alot easier and bleed it yourself but i would recommend getting the remote bleeder...much better option
What is the remote bleeder? I went and got a Mity Vac, I didnt get any bubbles when using this. I tried to bench bleed the MC before putting it in, I guess I got all the air out already? I still want to do traditional bleed to flush old fluid out.
http://www.tick-performance.com/tick...ulics/#bleeder
Get a REMOTE BLEEDER. A remote bleeder is just a line running from where the bleeder screw installs on the slave. It has a fitting on the end that has a 1 way valve inside. You route the line to somewhere (engine bay, frame ect). You open the valve fitting then press the clutch and bleed out the air. The valve inside the fitting closes when it loses pressure Thus keeping the hydraulics air tight.
