Buy a 2.2k Ohm resistor from an electronics supply shop.
Pull the plug for the CAGS solenoid on the driver's side of the trans. Stick each end of the resistor across the two pins in the plug. Tape it up so it wont get wet.
You're shifting problems are over.
