Stubborn Shifting
Stubborn Shifting
I've had this issue for a while, it's not as bad as it used to be now that I've upgraded bits of my drivetrain, but it's still annoying and holding me back. When I try to WOT shift, I'll put the clutch in at the right time and everything, but the shifter itself will get stuck halfway into gear for a solid second before going all the way into gear. No grinding, so whining. The shifter just gets stuck for a second. Is this a hydraulic issue, or an internal transmission issue?
As of right now, I've got a Monster Stage 3 Clutch, along with a new slave and the transmission has fresh Dex III, all done 1000 miles ago.
Did you do the "drill-mod" on the line from the master to the slave? If not this could be part of the issue. Of course, internal transmission issues are also a possibility if this affects a single gear. If it affects multiple gears than this is more than likely a problem with fluid transfer moreso than a trans issue. Let me know a bit more about the situation and I will be happy to assist you further. Thanks!
It is certainly possible that this is relative to a weak and or failing Master cylinder or slave cylinder. But, you didn't reply relative to my question about the "drill-mod". Is it done?
