Need a clutch....Recommendations?
Hey guys Im just looking for a stock like clutch. As cheap as possible. I just need a clutch to drive around on for a bit and to trade it in. My clutch now is BAD. I think my flywheel is warped. I have a REALLY REALLY bad shutter every time I take off and basically have to slip the hell out the clutch to make it not shutter really bad.
I looked on ebay and found an F1 Racing clutch disk for $100 any one on here use one of these and can I reuse my stock pressure plate?
I also found a spec stage 1 for $260.
what do you guys think? Would you guys recommend something different?
The LS7 kit SDPC sells is about the best deal cost-wise, and it works well. All new parts from the flywheel back.
Don't plan on re-using your pressure plate.
You might get off cheaper by having your flywheel machined and just buying a new disc and pressure plate, depends on what condition it's in.
Though I am all about selling you a clutch kit you really may be able to find a stock assembly for less. Check our Google/Ebay/Etc...and let me know if you need anything else.
