clutch line release gone
i went to pull my trans for a rebuild and the white collar thats used to release the clutch line was gone. i tried using a couple different line seperators and tried using thin pieces of aluminum to release the tabs still not having any luck.
i pulled the master and fed it down removing it with the transmission so i could get the trans tore down.
Is there a tool to remove this? Where would i get another white collar so i dont have this issue next time?
