Friction Disc Question
Old 08-09-2010, 03:59 AM
JasonWW's Avatar
Default Friction Disc Question
Hey guys, I put a new LS7 clutch assemby in my 99TA and it's just not grippy enough for my tastes. It's got less then 300 miles on it.
Can I just swap the friction disc out for one that grabs better or will I have to swap the pressure plate as well? I'm not very familiar with interchanging clutch parts. Any help would be appreciated.
Old 08-09-2010, 07:10 AM
Black02SLPSS's Avatar
Well you could, i dont believe you would need to swap your pressure plate as long as its a full faced disk. Now if you were to swap to a 6 puck disk for example, you would probably need to swap pressure plates to one that has a higher clamp pressure. Are you thinking of going to a dual friction type or a full ceramic disk?
Old 08-09-2010, 08:00 AM
JasonWW's Avatar
IDK, I'm trying to keep it cheap if possible. It's not a daily driver and I'd like to chirp 3rd.
