autometer electric speedo: wired to VSS?
Old 08-23-2010, 09:58 PM
Boost-box's Avatar
Default autometer electric speedo: wired to VSS?
I have a t56 in my GN, and i heard you can wire the electric autometer speedometer into the VSS somehow so I don't have to buy the autometer adapter. Is this true? If not, then which adapter do i need to buy?
Old 08-24-2010, 09:22 AM
85MikeTPI's Avatar
If you have an Autometer electronic speedometer, the T56 VSS signal will connect directly to it and work fine. No conversion needed.
Old 08-24-2010, 03:59 PM
Boost-box's Avatar
So how do I go about doing that?
Old 08-24-2010, 06:32 PM
85MikeTPI's Avatar
Do you have the installation manual for the Speedo?
http://www.autometer.com/cat_gaugede...id=2807&sid=15
Covers it all...
Quick Reply: autometer electric speedo: wired to VSS?
