oil sturated clutch again
This makes the third time my clutch has gotten saturated with oil. First time was bad rear main seal second the freeze plug in the center of crank was leaking this time I am really lost. It doesnt seem as if there is any way the plug in the crank could be leaking and I use sealer on the flywheel bolts. Anyways it is a 4" eagle crank and any ideas on how to stop the leak would be great.
Thanks
..RJ..
Thanks
..RJ..
