A4 to M6 Reverse Solenoid
Old 09-05-2010, 07:01 PM
Gordon0652's Avatar
Default A4 to M6 Reverse Solenoid
I have used the write ups for this but i did not see where it says to do the reverse solenoid, can someone help me out with this? Just need some idea of where to wire it to.
Thank You
Old 09-06-2010, 02:54 PM
Gordon0652's Avatar
Anyone?
Old 09-06-2010, 03:07 PM
85MikeTPI's Avatar
I see it in the FAQ:
https://ls1tech.com/forums/manual-tr...requested.html
Where are you looking?
Old 09-06-2010, 05:54 PM
Gordon0652's Avatar
Can you show me what post is about the wiring for the Reverse Solenoid?
I've looked...
Old 09-06-2010, 06:15 PM
85MikeTPI's Avatar
For an LT1 car, post #2. For an LS car, post #19.
Old 09-07-2010, 06:46 AM
Gordon0652's Avatar
Thank You!
And forget that, i'm just going to install a push button that will cut power to the solenoid so that i can put it in reverse and not put it in gear while power is to the solenoid.
I think thats how the solenoid works anyways.
Power-----Solenoid------No Reverse
No Power-----Solenoid------Reverse
Old 09-11-2010, 01:27 PM
RedRallyeZ's Avatar
there was one suggestion somewhere in there about instead of doing a switch wiring it to the brake lights, so essentially your brake pedal is the reverse lockout switch. i like that better than a switch if i could get some confirmation that it worked.
Quick Reply: A4 to M6 Reverse Solenoid
