Help needed!!!
Help needed!!!
So i know i need a new clutch cuz it started to slip last week. Took out the car for a ride today and while i was driving the car the car rpms would fluctuate and would bog out while driving. At one point my rpms stopped working. At a red light 1st and 2nd grind going in. My 3rd and 4th pop out when ever i get it into those gears. Like i said i know i have to get some trans work on it.
On the bogging part of my issue i know its not an engine issue cuz it only does it when im driving it. When im idle rpms are working and it doesnt bog out
Has anyone had this issue before and what did you find out the issue was.
how many miles on the clutch ? drill mod has sone some miracles .
then again , might want to go ahead and do a clutch swap . spec got some good prices as do other sponsors on here .
while you change the clutch put a new master and slave that way it has new hydraulics . cost some but do as much as possible when doing a swap .
Yea I replaced the clutch over 5yrs ago. it has a ram clutch. with a fandanza fwheel. I was thinking of doing the monster clutch wat about the trans. Should I get it rebuilt. Since it acting up real bad
