new tick master and gm slave still having issues
I just got back from korea and had my trany rebuild new rear and new tick master cylinder and gm slave cylinder i am still having issues with the clutch not disengaging at high rpms. have bleed the clutch and got all air out ... has a ls7 clutch that is farely new ... old master cylinder was leaking. i seem to be cursed with this issue and have never really been able to get rid of it .... any ideas of y im still having these problems ...the car has no issues as long as it doesnt go over 4,500 rpm.....
Personally I think it is a flaw of the self adjusting cover. I went through the LS7 and also a SPEC LS7 stage 3 with adjusting cover and both would not shift over 5k. The SPEC was actually worse than the stock LS7. They both start off shifting just fine then over a course of months the LS7 wouldn't shift. After only a few weeks the SPEC did the same thing. Ever since I installed an Exedy twin that does not self adjust, I haven't had a single problem with the pedal and its been in almost 6 months now. I didn't even use a pressure bleeder to bleed the system and no problems.
Anybody can say what they will, but I will not install another clutch with SAC pressure plate. I dont care if its factory stuff or not.
gm slave ... ordered it with the tick from tick the clutch has 5000 miles holds fine just doesnt disengage at high rpm ... thinking of a mcleod twin disc (cause i plan on a procharger later anyways) maybe it is the clutch cause it was the only thng not changed
What kinda problems? The reason why I ask is because I put a new slave in my car over two years ago and I have nothing but ******* problems with something and I cant put my finger on it.
