Hard to get into reverse with MGW shifter?
So I recently did a clutch change and also installed an MGW shifter. After these two things, it seems extremely hard, almost impossible at times, to get into reverse.
I did a search on Google and it seems like a few Mustang guys were complaining about something similar. But I wanted to see if anyone on here was having a similar problem with an MGW?
Pumping the clutch seems to help, kinda.
The car will shift into reverse when it is off. Is there any possible downsides to shifting the car into reverse while it is not started?
other than the fact that its a pain in the ***, you are probably wearing down your syncro's in your forward gears when shifting. If pumping seems to help a little, it sounds like youre not getting enough hydraulic pressure built up in the system, which means youre not getting full disenguagment of your clutch. If the clutch is dragging, its going to wear out your clutch and tranny. You wont hear the grinding in forward gears because they are syncronized. I missed the fact that its an lt1, so I think those hydro systems come as a complete unit? Master to slave? Your clutch hydraulics could just be getting a little old and tired and decided to show its ugly head when you put that ram clutch in.
Also, the slave and master cylinder were both replaced (separately) the same time the clutch went in.
i've tried shifting into second and then shifting into reverse, It doesn't seem to help.
I'm missing up the syncro's by shifting it while the car isn't started? I shift it from first (my e-brake doesn't work well) to reverse and then start the car. That's going to cause issues?
I had absolutely NO problem going into reverse before MGW shifter. Now its a pain in the ***. i almost pulled muscles in my shoulder trying it the first few times. I think its the stiff springs + shorter shifter increasing the effort to get the shifter into reverse. All I know is I had no problem before. If your shifter wont physically go into reverse then I agree its a clutch issue. AFTER the MGW shifter I am having issues into 1st sometimes at a stop light. If I pump the clutch 2x it slides in easy.
I'm not sure how to approach this with the LT1 T56, but I had the same issue with my MGW shifter. Replacing the clutch master cylinder with a Tick unit turned the ****** into a stick of butter. So my guess is something with the master cylinder.
I haven't dealt with any of these personally but it seems that a lot of people are having problems with reverse after going to the mgw shifter. The problem is that it seems like everyone does a clutch at the sametime so it seems that it would hard to narrow down. There are a few guys with the LS1 that have some open threads and they seem to have it narrowed to the slave/master. Fwiw.
its not ur shifter. i had the exact same thing happen to my 93z when i put the ram powergrip clutch in it, which i see by ur sig thats what u have...those clutch disks have a tendency to be to thick (at least on lt1s), so its not disengaging all the way, and i could not for the life of me get it into reverse after the install but after i drove it a lil bit it started getting easier and easier to get in reverse
Want to fix it for me?
Here is my thread about the Ram Disc problem if you're interested in the exact details of the real problem:
https://ls1tech.com/forums/lt1-lt4-m...ange-help.html
New thread, new symptoms, same problem.
https://ls1tech.com/forums/manual-tr...-symptoms.html
Thanks for any and all the help guys. It's appreciated.
