Grinding 5th
Old 09-27-2010, 09:28 PM
NewLS1Owner's Avatar
Question Grinding 5th
Ok. I'm new to having a manual transmission. I bought this car back in June, had it 6 days and blew the engine. I had it rebuilt and had a new clutch put in it at the same time. I don't know which one. It worked fine for a couple of months, but now 5th gear grinds sometimes, especially at higher rpms. Is this a transmission problem or a clutch problem?
Old 09-28-2010, 06:44 AM
85MikeTPI's Avatar
Is the Reverse lockout in good working order? Does it only grind on up-shifts, or down-shifts, or both?
How high RPMs are you shifting into 5th? 120+mph ???
Old 09-28-2010, 10:10 AM
TDP
TDP's Avatar
Its a tranny problem. Most likely a worn synchro assembly. If you have any more questions or need it rebuilt, feel free to gimme a holler. I'm in your area, just check my sig..
Old 09-28-2010, 12:40 PM
thegodfather899's Avatar
X2 i agree
Old 09-30-2010, 08:17 PM
Thanks for the info. I'm gonna have to drive it as is right now. I'll just have to be careful of 5th until i can save up enough for a rebuild.
