Master problems?
Master problems?
Seems like when I release my clutch it changes where it engages on the pedal. My car has 85k with a spec 3, the clutch probably has 15-20k miles. Barely any drag racing.... The tranny could use a rebuild since it seems to shift not so smooth.
Is this a symptom of a master going bad?
Thanks, I plan to get a tick adj.
Did you go through any of the Hydraulics when you swapped the clutch? Slave or Master? Ram makes a nice Master as well which we have on our website.
http://www.neweraperformance.net/def...E&PKV=ram510|0
LS1TECH Sponsor
The RAM Master is a joke. Our piece and the McLeod are the only two on the market capable of flowing a significant amount more fluid than the stocker.
Check our FAQ here for a very informative read: http://www.tick-performance.com/tick...aulics/#master
