Think my trans is hurt
Okay so im jsut getting to the point where im street driving my new rear end and i noticed a little bit of gear whine. Thought it was normal, after all the new gears are richmond 4.56s and are going to be louder than most, but then i noticed something...
the noise went away when i pushed the clutch in
This is the first time ive been driving my car since my rear end took a dump at the drag strip nearly 4 months ago So it could have been sitting there broke the whole time without me knowing it.
It gets louder with speed, is hear on accel and deaccel and goes away with the clutch in. It also seems like the trans might be running hotter than normal if that could indicate anything.
Sound like trans noise or gear noise?
Still sounds like rear-end gear whine, it just lessens when you unload the drivetrain from the motor by pushing in the clutch.
Was the driveshaft damaged when the rear let go? Have you ever measured for driveshaft bind?
