T56 vent tube....what's the white thing on the end/top?
Old 10-04-2010, 07:51 PM
jonathan_ed3's Avatar
Default T56 vent tube....what's the white thing on the end/top?
I'm not going to spend $50+ to buy a new vent tube since mine is missing.
I noticed on a friends T56 at the top/end of the vent tube there's a white cap thing that kind of swivels.
Is it a one way check valve, or just a cap, or what the heck is it?
I was just going to route some transmission cooler line up to about the bell housing area, but not sure how to top/cap it off at the "open" end.
Any ideas/information on this topic?
Old 10-05-2010, 07:46 AM
thesource's Avatar
Yes its a pressure release valve.
Old 10-05-2010, 08:46 PM
Is there a way to replicate it using something off the shelf?
Would a one way check valve (from like a vacuum line or a brake booster etc) work the same as a "pressure relief valve"?
Old 10-06-2010, 10:00 AM
jmd
jmd's Avatar
Post
Dorman 14689. Dealer has the same item too. It might fit the stock tube, it might not.
It's not a check valve. It breathes whereas a check valve does not.
Old 10-06-2010, 10:26 AM
thesource's Avatar
I would just use some rubber hose about the same lenght and a breather valve off of a differential.
Old 10-06-2010, 09:45 PM
Thanks a bunch guys! You are always life savers!
Quick Reply: T56 vent tube....what's the white thing on the end/top?
