questions for those of you with a Tick
Old 10-30-2010, 01:29 PM
ss1le02's Avatar
Default questions for those of you with a Tick
I've got one. I've adjusted it like the directions say, and then some. I still can't power shift past 3rd gear effortlessly. 1st and 2nd are fine, thirds notchy, fourth is a crapshoot if it will go in gear. Pedal hangs on the floor after speed shifting. What I mean by speed shifting is bring it up to redline then shift while letting off the gas between shifts.
Clutch is a LS7, been bled a few times, adjusted different ways.
Any help.
Old 10-30-2010, 09:16 PM
RARON455's Avatar
weird,, before I got my tick, I couldnt get in the lower gears, Your situation is completely opposite with the higher gears, What shifter are you using?
Old 10-30-2010, 09:26 PM
Mikey 97Z M6's Avatar
Sounds like more of a slave cylinder or pressure plate issue to me.
Mike
Old 10-30-2010, 10:45 PM
ss1le02's Avatar
Mike
I guess over the winter I'll get a new LS7 clutch and another new (slave cylinder ).
Old 10-31-2010, 11:58 AM
CW00BlackTA's Avatar
After my previous clutch change my shifting was noticeably more notchy than it had been. Nothing fixed it until I did a minor rebuild to replace the usual culprits. Now it shifts smooth again. Something to keep in mind if you have to pull the trans any way. It's not that difficult.
Old 10-31-2010, 02:23 PM
ss1le02's Avatar
The tranny's been rebuilt already. I think it's time for a vette.
