6 Speed
6 Speed
I am new to the LS 1 style motors, have always run early SBC.
Will a early style scattershield work on a LS1 motor with a Richmond 6 speed
or will I need some kind of a spacer for it.?
Thanks
Speedy
Thanks
Speedy
https://ls1tech.com/forums/sponsor-g...xplate-gp.html
Thanks!
I appoligize I misread what you were actually wanting to do. I thought you said
"Will a early style scattershield work on a LS1 motor "from" a Richmond 6 speed
or will I need some kind of a spacer for it.?"
Yea as TDP said befor, no way would I used a richmond. They are VERY old tech. They work basically like an old Muncie or Borgwarner 4 speed. They use bronze blocking rings which do not work even half as well as the carbon rings available for the T56.
You may notice that one of the sponsors here is making a 3/8" plate so the F-body T56 input can be used with the CTS-V pilot bearing. That bearing sits in the larger, further back portion fo the crank. That bearing might be enough to make up the difference. There are extended pilot bushing options too. Measure.
As for the synchros, I enjoyed driving a friend's Richmond 6 (3.01 first, .6x sixth) and if I had one, I would be hard pressed to justify going to a T56 unless the Richmond was breaking. Some of them are already 32 spline (TH400 size) output.
