Brake fluid leaking
Brake fluid leaking
I replaced the slave cylinder and stainless steel hose last year because of brake fluid coming out of the bell housing drain hole. The car sat for about 2 weeks and when i went to move it, i noticed some fresh stains of brake fluid right under the trans. Could my new 01-02 slave cylinder seal be bad??
Also i noticed after driving it for awhile the fluid was getting very dark again, although i flushed it all out and put new stuff in, it didn't take long to get dirty. But on my other DD manual car with 90k miles on the clutch fluid is still clear. Is there that would cause this?
