Swap guys! need help asap
i put my key in and turned it on to check power, after i turned off i noticed key key wont turn all the way back to get it out. theres probaly wires that need sliced but i dont know which ones?
OK i figured out that the console plug with 6 wires is where the wires come from for the neutral safety switch, are these also the wires i use for the reverse lights and hatch release? or do those wires come from another harness? Can i use the wiring harness that pluged into the auto for wires to connect reverse lights? thanks again guys its almost over
