View Poll Results: Is your firewall cracked near the Clutch Master Cylinder?
Yes
3
21.43%
No
11
78.57%
It was but I fixed it.
0
0%
Voters: 14. You may not vote on this poll
Who has a crack in the firewall by the clutch master cylinder?
Old 11-21-2010, 03:48 AM
_JB_'s Avatar
Default Who has a crack in the firewall by the clutch master cylinder?
Title says it all. When I was installing my new turn signal flasher today, I notice I have a crack in the firewall where the clutch master cylinder attaches. I've hear about this before, and I'm wondering how common it really is.
I have a Tick MC installed for about two years now, and I KNOW it wasn't there when I installed it.
Old 02-11-2012, 11:11 AM
tazmo65's Avatar
I have one in mine. The stiffener on the inside and the cylinder push through the firewall about a 1/4 inch on 1 side.
Old 02-11-2012, 03:08 PM
Spartan7's Avatar
I did on my last car. It was an M6 conversion, so it didn't have the additional brace plate like stock manual cars. I only noticed it when I went to install my new McLeod MC.
Old 04-01-2012, 10:29 AM
Blksilvr's Avatar
About three years ago I paid a speed shop to convert my A4 TA into a M6.
My clutch felt soft and after checking I found the master had a leak & I paid to have a Trick shift master installed/ night and day difference .
So now to the present...my clutch seemed to be light , but not all the time. After checking , it had a slight leak . After my brother and I remove it is when I found the firewall cracked and how the company I paid to do the install butchered the firewall and did not install the backing plate. ( even though they have done numerous conversion ). So I am now making two plates , 16ga sheet metal ( one on the inside and one for the out ) . Right now I have it bolted in with grade 8 bolts washers / I use the mug welder on the edges later.
Old 04-02-2012, 10:51 AM
CamaroSS27's Avatar
I dont have one
Old 04-02-2012, 11:05 AM
_JB_'s Avatar
FWIW, my car is originally an M6 and it also has the backing plate installed. I haven't checked on it since I made this thread, so I guess its ok...so far lol.
Old 04-02-2012, 11:25 AM
wrd1972's Avatar
Post a pic
Old 04-03-2012, 11:31 AM
OldCobraGuy's Avatar
One draw back to the large bore master cylinders is the extra effort it takes to release the clutch. That can contribute to this problem. Extra bracing might be a good idea for Tick and Mcleod to consider offering.
Old 04-06-2012, 08:09 AM
_JB_'s Avatar
Sorry it took a few days, but here it is. It doesn't move much, but if I put my thumb on it and press the pedal you can feel it move into the engine bay.
Old 04-06-2012, 08:52 AM
You know, Ford also had this problem with their manual trans trucks. They developed a brace that flat cured it. If it cracks, and you don't fix it, you could have one helluva mess after a period of time.
Quick Reply: Who has a crack in the firewall by the clutch master cylinder?
