how to shift with no clutch??
hey guys is there a sweet spot in the rpm range that i can shift my firehawk with out the clutch ??? i shift now at 6600rpm with the clutch and i was told i can drop a tenth or two with out using a clutch
You can shift your tranny at any rpm without a clutch. The key is to match the engine rpms with the rpm the clutch is spinning.
I use to drive my 1992 3000gt vr4 without even using the clutch, same with my 94 Miata M edition I had. Only time I had to use it was when I was at a stop.
Any manual gearbox can be shifted without the clutch. Whenever you are changing from a lower gear to a higher gear it's easy because the engine is turning faster then the wheels. Just let the RPM's fall to just before the speeds are matched and slip the gear in.
Downshifting is a different skill because you have to blip the throttle to match the engine revs to the wheels.
What the hell are you doing anyway? Just use the clutch.
Shifting is, once you've understood the basics, a personal preference of the balance between drivetrain life and speed. In a normal "street" shift, you either pop the gear out by lifting off the throttle or clutch in, allow the revs to fall to the perfect point as you slide the gear in with or without the clutch and then continue with power. It is smooth. It is also slow.
In order to negate this, during an upshift in aggressive conditions you will want to get the gear in with the rpms a little higher than "perfect". This will give a little boost(can't describe it another way), you do not have to wait as long for the rpms to fall, and you will be quicker. But it has many detractors: increased wear, increased difficulty, not as smooth, etc. (This is also why I said "Full Powershift" above, because this is essentially a powershift of its own, but it does not stray nearly as far from the rpm difference of the wheels and engine.)
Basically, the further you go rpm-wise from a perfect mate of engine to wheel speed, the more you run the risk of missing a gear and the faster you wear out your drivetrain.
(NOTE that if you don't use the clutch from neut->gear you will always have a little "jolt", that is more wear for your trans and the pros recommend you "jab" the clutch to the engagement zone to soften this)
Hope this helps.
Or go with a powerglide tranny and use pedals. Ir you can do what im doing and learn to powershift. Then once I learn im rebuilding tranny and putting on my monster clutch. But it is possible. My uncles do it on their semis. He did it on my car as well. I can't do it tho
