T56 And 408 Install Help
Swapping from 400 to T56 Does anyone know if Clutch and flywheel from ls1 car will work with 6.0 block? Dont know if there is a differnt clutch and flywheel, shims, etc.
Thanks
Thanks
As long as the crank face is the same depth from the block face as the LS1 yes. Early 6.0s had a thicker rear flange to mate with the 4L80-E converter (which was originally intended for use w/ 4.3 / 5.7 / BBC depth crank flanges) and then they used a spacer when the cranks went to standard LS_ depth.
